My 4GTL has failed its MOT because offside rear brake is not working effectively. The handbrake works fine but the foot brakes are seriously imbalanced. The wheel cylinder is new-ish and does not seem to be leaking. With the drum off I can see that depressing the brake pedal makes the piston operate but obviously not enough. With the pedal depressed and the wheel jacked up it can still be turned relatively easily by hand. I have bled that brake. Hydraulic fluid looks clean and bubble free. To get the drum back on I back off the handbrake adjustor - is this a mistake? Should I just keep bleeding? I've done about 10 complete pushes of the pedal. Any ideas? Many thanks in advance.
