Hello,
I took my r4 GTL for MOT and all passed but rear brake on driver side failed
What they told me is that breaking force comes in too late compared to other side and also brake force is not adequate on left side.
Not long ago most rear brake parts were replaced, so there are new brake shoes, wheel cylinders, new springs etc.
Any tips what I should check?
There is no air in the brake fluid.
One guess is the adjuster is not working as it should and that's causing the trouble.
What can be wrong with it?
Also the brake force adjuster (or whatever it's called the thing that adjust brakes depending on weight on rear seats) is not connected, but I suppose that should not results in MOT failure.
Regards,
Zsolt
Regards,
Zsolt
