reidalpine
Ok guys,new topic for the week-end..Since none of us has a proper life anyway-i'm trying to keep
you all occupied this week-end to keep you from any mischief you might have planned.
I've always used the green antifreeze (glycol-based) If I recall all the other R4/4L's I've been
peering into the engine-bay of has had the same green stuff...
-Aren't all these R,G,B-colored products glycol-based And for use in iron/alu-engines?
maybe with different rust-inhabitors,additives etc but basicly correct for us?
Now as the time nears for my new engine,I thought about that insanely expensive Evans "The ultimate
cooling solution" as they call it. contains absolutely NO water, withstands 180C.so no boiling and near zero pressure in system,so top-end gasket should have a fighting chance too.
Expensive at Nok:695/€76 per 5L (and you need to fill to usual level,so needs even more than 5L)
and this is ONLY for the prep-fluid (hydroporic)that has to be used to get ALL water out of system.
Then you'll need the actual coolant that will set you back another Nok.790/€86 for 5L,so you need
an additional Litre or two...
Question is, is it worth it? I mean on the up-side they say it'll last you 20 years !! but you better make sure you don't have a leak in the system.Also on the up-side is it's waterless so no more NASTY rust,gunk and nastyness clogging up the system.bad or No heat inside car.Bad cooling for engine,failing water-pump,leaking hoses etc etc
I've been a Good lad changing every 2 seasons using name-brand product plus demineralized and boiled water but despite this I'm Always blown away by just how filthy and rusted it looks inside when dumping to renew it..
so hows about it gang.. Worth it? tried it..-and?? Tips? Advice? -I'll take them all!
-R.
-R.
