The "Renault 100" aka the articulated swinger loader model made by continental that uses the 1098 cc engine (from R10 Caravelle 1968 gas engine) Just imagine the Renault engine placed in a tractor with a bunch of unusual changes such as the carb, exchaust, water pump, etc.
Anyway, a little while ago I did an engine rebuild new gasket seals, some new bearings (another stupid design that was added called a gEar driven governor) that caused some metal pieces to get sucked through the engine. Anyway, the rebuild process went pretty smooth. New rings were installed. Ilive in the states so parts are more scarce around here for a 68 motor by Renault. Two things that I couldn't find were the liner seals and valve seals. My main concern is how do you guys install the liners? I used omega black ATF that is oil and coolant resistant. Is this OK? I've also read that some people don't do anything at all? (no seals I mean).
The other thing that I had a question on was the milky white oil under the oil cap. Some people say that the tall valve cover causes more condensation build up during winter, I checked my oil and it looks clean. Drained and will recheck again. Not sure if this is a common issue in the winter time since I haven't run this engine in the summer yet.
Appreciate any input.
