Seasons greetings. I am starting looking for a Renault 4, preferably an F4 van with windows, but I would consider a car dependent on it`s condition. I do not want a "minter", I have dogs and I will use it too much to do it justice. On the other hand I do not want a restoration project; I already have a Mercedes T2 minibus that is a long term conversion and restoration project. I`m afraid that if I cannot drive it home then I am not interested. The prime concern is that it should be structurally sound. Mechanically it should be OK, and with an 1108 engine. Originality is not an issue, mods to improve drivability /usability are fine. Whilst I am not looking for a fire breathing gordini powered street sleeper, I will be towing a trailer and want some torque. I do not mind if it is cosmetically challenged, I will be respraying the Merc when it is finished, and could do both at once. If it is a van it must have a lift up rear roof, and either have some side windows (need not be full length) or if second hand windows and new seals are available, that might be ok, depending how much other bodywork is needed. If it is a car then a RHD GTL or modified model is favorite, but it must not be white unless it needs a respray. If it`s a van then I am happy to compromise to LHD, but I am not looking for an F6. You the vendor must be happy that I will be fitting your vehicle with a towbar, A frame fitting points and that if it needs respraying then it probably won`t be a factory colour.
Its christmas and you are busy. Frankly spring is better for me, but if you have a suitable vehicle tucked away and are considering selling it in the new year, then please bare me in mind.
Have a good christmas! Swampy
