renault 4 towbars
bermudasaab
I have lost our renault to my daughter but it needs a towbar to drag start my SAAB 900 also there is bubbleing above rear wing is this fixable my daughter loves the car having just passed her test also need a drivers seat :(
I assume none of the towbar companies in the phone book will knock up a towbar? Othersire try Liam (posts on this foum and might have a secondhand one).
The bubbling above the rear wing is common. Water gets trapped in the joint between the bolt on lower section and the body and causes rust. If the body has rusted through then welding is the answer, but it's a tricky area to weld neatly as the panel distorts. It's not really a structural area so a cosmetic repair (filler and paint) is also common in that area.
