Paul Narramore
pre-moderated
- Aylesford, Kent
Right, ignition timing, a subject I've steered clear of during all the years I've been dabbling with old cars. Partly it's because I was scared that I'd upset things and make matters worse. However after fitting Aldon electronic ignition last week, it became apparent I couldn't simply leave the timing alone even though I'd not removed the Ducellier distributor. Oh well, let have a go and see if it's as easy as people say. It often isn't.
At this point you old sweats who have done this over and over again can go and find something useful to do, as this is for us sprogs.
Refering to p264 of Haynes, the first thing is the dreadful and grainy 60x50mm illustration (Fig12.46) showing the timing marks. Very inaccessible, I spent quite a while cleaning up the surroundings of this little window with a small screw driver and steel wool to find not two marks but quite a number, even a pair on the opposite side of the window. As my image shows, it's the pair almost tucked under the small bolt head. Highlight the two marks with Tippex and ignore any other neighbouring marks.
Now the 'bar' the flywheel around until the notch, a very feint one at that, appears in the window. Put a dab of Tippex on that. To bar the flywheel around, I tried to use a 17mm socket on a 1/2" drive ratchet but it seemed a loose fit and I lost a bit more skin as it slid of the hexagon nut. 5/8"A/F was a snugger fit.
Remove the vacuum advance pipe from the end of the distributor and plug the end of the plastic tube with a self tapper and masking tape.
Slacken the 11mm A/F bolt which clamps the base of the distributor, a few turns. To gain access to this, take off the No3 HT lead from the No3 plug then replace it after the bolt has been slackened.
Borrow a strobe from a friend - mine was ancient, very dusty and the light was a little feint - remove the H/T lead from No1 spark plug (at the front and nearest the radiator, clip one of the two leads onto the spark plug and push the other lead into the H/T lead (plug cap).
Start the engine up and allow the engine to tick over. Make sure the dangly leads don't touch anything spinning like the alternator fan blades (as it makes a noise which will make you jump) and point the strobe at the marks. Well bugger me, the mark on the flywheel was just to one side of the two marks, which showed it was a touch retarded. A slight tweak of the distributor body and the feint flywheelmark comes within the two marks.
You could also follow Haynes' tip to check that the centrifugal advance mechanism is working .
Turn off engine. Tighten up the distributor clamp bolt. Remove the strobe and replace the plug cap onto No1 plug.
I've noticed already that the tickover is a touch smoother so time to take her for a test drive ;-)
PS If those Tippex marks don't look too sharp to you, remember that access to this window is very restricted and Parkinsons hasn't kicked in yet.
