Renault Scenic RX4 Problems
EwOkiE
Right I have just been given a Renault RX4 Scenic 51 Plate.
With a few problems, which are :
1. No Speedometer working (but revs working ok)
2. STOP,Serv (intermittent),ABS (intermittent),Handbrake all light up on dash whilst driving
Have just been back from a garage which checked the fault codes : It has the F9Q Engine (If that makes sense)
5 ABS POWER SUPPLY
31 INJ ABS CONNECTOR
00032 UN DOCUMENTED
06161 UN DOCUMENTED
Any help would be appreciated.
Hi,
The speedo on the normal meganes takes its pick up off the ABS pump/computer. There is also a connector on the drivers side under the scuttle panel which the wires go green and break... there maybe the same system on the RX4 but this may help you
cheers
andrew
Thanks, may check these.
Is there anything I can do to try and resolve this rather than a garage.
