Replacement shift knob?
Does such a creature exist? If so, where do I get one, please?
If yours is loose or broken I can tell you how to repair . If really stuck I do have the complete hockey stick which is the best way to sort it- knob cannot bd removed under normal circumstance
The knob just comes off in my hand while shifting! I need to shift less vigorously
It can be repaired with Slow cure Araldite - remove complete hockey stick from car. Turn upside down and push the araldite resin into the gap at the bottom. It will slowly sink down before setting
