Hello Speedo19,
The fault is usually the Switch which is in the L/H side of the gearbox around the drive shaft area, If you can get the wiring plug off the end you can put a small bit of wire between the terminals (don't let the wire touch anything)then turn on the ignition and if the lights come on you need a switch, If your not confident Please get a mechanic to look.
