Hello again,
The other thing I'm about to do is take off the rocker box to give it a clean out (some emulsification of old oil on the bottom of the cap - I hope from little use rather than gasket leak), prior to doing an oil flush and change.
1) I presume I'll need to buy a gasket?
2) should I re-tighten the nuts to a particular torque (in which case I'll need to buy a wrench), or can I be sensible with a socket set and just beware not to over-tighten?
Help and advice greatly appreciated as always!
