malcolm
& Clementine the Cat
- Bedford UK
There is a weird thing going on with the Rodeo. I took it out to the supermarket at the weekend for it's first trip of the year (7km). It took a long time to start when I got back to the car. I moved it to the petrol station and filled up and it took a couple of minutes to start. Drove home. It was a bit hesitant on acceleration and it conked out on my driveway.
I opened the bonnet and the fuel filter was empty and turning over the engine didn't squirt any fuel into the fuel filter so I think the problem is fuel supply.
Today I checked the filter gauze in the carb inlet pipe. That was fine but I cleaned it anyway. I replaced the fuel filter just in case but the old one looked OK after I cut it open. Tried blowing through the pipe into the carb and that felt fine. Tried sucking fuel up the fuel pump inlet pipe and it comes through OK and holds fuel height so so sign of leaks.
The fuel pump is new but might have failed, but I tried turning the engine over again and it squirts petrol into the filter fine now. I'm a bit baffled. Float chamber vent blocked maybe? Any ideas?
