Chris Litchfield
- Baldock, Herts, UK
Hi all
I am worried about Ruby, my 1981 R5 GTL.
On a long hot drive in August the warning light came on in a traffic jam. Switched off immediately, let her cool down and eventually drove home without the light coming back on. Haven't driven her since.
Today was my first chance to look at her. Have tested the thermostat & all ok. Have flushed and refilled the coolant and replaced the radiator fan switch with a new one. Did bypass test on fan and that works.
Have bled the system, heater is warm. Ran her idle and the fan hasn't kicked in. Took her for a little run (she was running fine) and then let her idle and fan still didn't kick in, although hoses and fan switch felt hot.
I noticed a couple of bubbles in the expansion tank, so got scared and switched the engine off. I didn't want it to get to the point of the dreaded light coming on.
Am worried I have damaged her engine. My technical knowledge is limited, so I need to get her checked properly.
If anyone has any thoughts or advice, I would really appreciate it.
Cheers
Chris
Cheers
Chris
