Hi I’m new here and wonder if you can help me. My engine has been rebuilt using new liners/pistons and big end shells, it has had a new chain tensioner also, the main bearing shells and thrusts were all in good condition. When it starts it has good oil pressure and initially sounds ok, then after a few seconds a noise comes and the engine seems to slow down a touch. Having the clutch pressed makes no difference, as does running it for a few secs with the belts off, it is a rumble but similar sound to a belt and pulley noise.
