I think you will find that on that year scenic the ABS sensor picks up off a toothed ring (reluctor) on the C.V. joint part of the drives shaft.
Check the wiring has been plugged back in properly, if you can get a multimeter in to do an ohms check (from the plug down to the sensor) you are looking for a typical reading 900 to 1200 ohms resistance.
Stopping the bulbs working will only save the strain on your eyes as any half switched on MOT tester will see the ABS unit under the bonnet and then fail the car because the light doesn't come on when it's first turned on.
you haven't said yet if a garage did the work for you or if was yourself/friend, if it was a garage definatley take it back and see what they say, you should at least get a discount on the labour. If you have to leave the repair till a later date your brakes will still work as if they were 'normal' brakes, ie without ABS.
