got my '67 850 back together after a head gasket renewal, but she's not wanting to start......
am i right in saying there is only one way a distributor can be put in (i removed it and turned the engine over a few times before putting it back in)? i marked its exact position before i removed it
also, i've set the valve clearances to + 0.2 mm on top of standard clearances (i.e. almost double) as per Haynes....is this right?
although i'm getting a spark, i'm not sure i've got the electrics totally right: does the earth wire from the dizzy go to the dizzy fixing screw into the block....and is the alternator wiring thick black wire to large stud, green to small top stud and pale (grey?) wire to small bottom stud
she's been making a phutting noise when turning engine over.
any help much appreciated....Adrian
