I'm having to replace the starter motor (bearings totally worn out) and read a thread recomending that the n/s engine mounting could/should be replaced at the same time. Do the rubber blocks get tired/worn and is this the part of the assembly that is referred to for replacement. (I went to the local renault dealer on Benfield Road here in Newcastle and they were friendly and helpful and bought both n/s and o/s bracket with blocks for £87.) They gave me a screen printout of the complete engine mountings and their assemblies to identify the bits I wanted. Am I changing the correct bits or is it the mounting bracket bolted to the chassis which should be renewed? I'm still psyching myself up to do the bottom front balljoints but the starter motor is more urgent and has nudged into pole position for fettling. I was known as "Brian the Mollusc" for years - A do nowt in a hurry- snail pace.:roll:
