Hey guys,
I'm new to this forum but have regularly persued it with my dad as he used to have a 4 that we messed about with a lot. I have had a 1990 Renault 5 campus for the past 18 months and have had a few jobs to do on it but this one has got me stuck.
I am rubbish with electrics but parked it up one day and since trying to start it there is no spark. I initially thought it was the coils but swapped that out with no luck. I have had the multimeter out to check the ignition circuit is ok up to the coil is OK and it is. I then replaced the condenser and no luck.
Otherwise im stumped. I pushed to a garage around the corner and they said that they got a weak spark if they just hooked the battery up straight but that was it. As far as i know they checked the earth was good. They did say that it may be the ignition module (a silver box that sits next to the coil) but they said they weren't sure. I dont think this can be right as i would have thought the problem would be in the coil if the spark was weak with just the battery straight. i didnt think this box amplified the current at all?
Anyway that probably sounds as confused as i feel but if anyone has any ideas i would much appreciate it!
Thanks,
Luke
Thanks,
Luke
