You RHD-guys are much luckier! I think you only have to remove the bridge on the LH engine mounting and the motor will be free to remove. Compare this with a LHD car:you have to remove completely the handbrake mechanism(drum-braked R4s),disconnect the steering column so that it can be moved a little to the side, and then you have the master cylinder on the way...really fiddly.A "half moon" ring spanner is very useful for the inaccessible 13mm nuts,too.
