PHILIP BUXTON
I have read threads on starting difficulties and suspect my solenoid as suddenly nothing happens at all when I turn key, not even a click. I was told to tap starter motor with hammer to release it and this has worked in past (I had same prob approx one year ago and having tapped starter problem went away completely until now; ) I don't understand how everything can work one minute and not the next! I have charged battery which seemed ok.
Apart from advice given in articles in forum (check earth leads etc) is it at all possible to try and clean solenoid in situ or remove solenoid for cleaning without removing starter motor,which I am convinced is beyond me .My car is a left hand drive.
I think in Haynes manual it says if you turn starter with headlights on and these do not dim then current is not getting to starter motor so problem is with solenoid. I do not discern any dimming of lights when starter turned
