kevinandkate
Sadly no longer an owner
With no great surprise I have to say, the clutch on fifi is slipping and closer examination reveals an extremely stiff external actuating arm. Its the later type that pivots on a rod through the gearbox and no ammount of waggling too and fro with the aid of two bits of wood and rope will free it off properly. As a result the clutch doesn't release properly and therfore slips. Before I resort to removing the gearbox and getting close up with the errant clutch, any ideas of where some release oil could be sprayed onto the splined shaft as Im sure this is where the clutch plate is sticking. I cannot see any likely apertures to spray through and it seems a bit pointless spraying ad hoc as it will go onto the centre plate and hey presto no clutch. Sneaky Renault 4 brains required here I think.
