SeaKayaker
Maybe I am doing something wrong?
I want to check the ignition timing, as my new R4L (1979=1108 with ducellier & vacuum advance) pinks just slightly, if I use, say, half throttle (or more) when accelerating. New points, condenser, plugs, leads, airfilter, running on Sans Plomb 98 with lead substitute additive. I have a strobe light, I have marked the "notch" on the flywheel (which confirms the rotor arm pointing to spark plug lead No.1 ) with tippex. But, when I use the strobe light, it does not show the mark in the bellhouse window at any time. I can see the flywheel advancing, when I increase the engine revs, But, there is no sign of the flywheel mark. As a by the by, have just ordered a Boyer Bransden unit, which seems to be the best option, keeping the R4 Philosophy in mind, and will fit that next week.
All advice welcome.
Sea Kayaker, in the south of France
All advice welcome.
