The speed change lever knob
Pavel
Hi, have you any idea, how to remove the speed lever knob, without damaging whatever? Many thanks Pavel :p
Unfortunately it is not possible, the knob seems to be bonded or moulded on the lever. I have come across one or two knobs, though, that were already loose on the lever (!) and were very easy to remove.
Do you need another one? Or are you trying to get it off to replace it with something ele?
If you need a spare I have one as the spares car I have has a loose gear lever already.
I'll post to Prague no problems.
The gear change bar just has knurled metal under the gear lever knob, I checked for you today.
I want let the rod to chrome-plate and for this I have to remove the knob. I have two cars and two levers, so may be the second one knob is looser on the lever, I didn´t try it as yet. So the new knob is not so hurry, but I´ll remember you, once the problem shall be actual. Many thanks. Pavel
