Hi,
We have had a R4 Gtl 1984, 1100, for 20 years, only 25,000 miles on the clock. We bought it from the previous only owner after seeing it sitting untouched on his drive, and used it for our Wedding day car. We bought it 20 years ago and it has sat in the garage/ storage for the last 15. Now our 2 boys are getting to an age to tinker (and we are not so tired!!), we are looking to get it back on the road.
Reading posts on this really helpful site, I have learnt that it will drive on unleaded without conversion- the last time it was filled up, it was with leaded! Amazingly, it starts straight away when turned over, which has happened about once a year in this time.
I guess I need to change the engine oil, drain and clean the water system and change the plugs and filters.I have been advised that the brakes should have a complete overhaul. Also, the clutch does not work and I am not sure if this is 'sticking' ,which I believe can happen, or needs replacing. How can I tell?
I would be really grateful if anyone can give me some tips on these points and if there is anything else that I should do before thinking about MOTs. I am of the generation used to tinkering with cars and I am armed with the original Haynes manual! Still, I am filled with some trepidation but want to try most of the work myself. Or, do you think I should send it to a specialist for an overhaul?
Jon
Jon
