Too much white smoke in breather pipe!
Ndelilio Nnko
Arusha. Tanzania. EA
Jambo! my babybush start to produce to much white smoke in breather pipe! After I change point. Distributor cam, rotor arm. Condeser.all are ducellier procuct. When l drive it too much white smoke came out of breather pipe? What is that? can it be failure of piston Rings? Is there any side effect when am continue to drive it??
Asantee
White smoke in exhaust could be just condensation or it could mean water getting into pistons but I'm not sure what it means in breather pipe.
Take the oil filler cap off and see if there's grey frothy stuff on the inside of the cap and in the rocker cover. If you have this it means there's water in the oil.
Which is a fairly serious problem.
Piston rings letting too much oil into piston makes blue smoke, not white.
Piston rings can't let water into pistons.
Have a look under cap before worrying though.
