TS engine code 810.
Crewealex
E4GTL in a past life.
Leigh
Hello, chums.
I've a 1289cc bare engine needing to be built up. New pistons/barrels+0.5. Head ported and reasonable. Block needs a good scrub. 1108 head fits. Crank good. Cam good. Up-rated flywheel and clutch. Most gaskets. This was intended for my car, but, once again, I've bitten off more than I can chew (I'm 81). It'll need your ancillaries and new shells.
Note, if you want to fit a TS carburettor (65bhp) it'll foul the steering on LHD cars. 1108 standard manifold and 32mm carb fits.
I've tried all engine/box combinations over forty years of owning various '4's (when Gordinis were £35) ((Yes, really)) and this is the best all-round engine for a '4' !
This is collect only. I'm in Leigh. £250 make any sense ?
