Eccles60
- Solihull, West Midlands
Sorry if I'm rather hogging this forum but being new to Renaults, I have many questions!
The weekend before last I drove my new purchase from London to Solihull, clocking up about 135 miles via the M25 and M40 at a steady 55 to 60 mph. The car ran really well but I noticed once I'd parked up that at least the top hose and expansion bottle pipe connections to the radiator were weeping and there was about a cup of coolant directly under the sump. The expansion bottle itself was still about half full but the coolant within looks a little murky.
I checked under the oil filler cap and it's nice and clean, dipping the oil the next day and it's up to the top. I've tried tweaking the hose clamps but methinks someone's beaten me to it because they are rock solid tight.
The hoses were presumably changed during its restoration barely four years ago and they still feel reasonably flexible but why the dribbles?
Talking to fellow forum member Pepper at the NEC on the Renault Car Club stand suggested using Type D coolant (amazingly reasonably priced from Renault) and warned me about not removing the radiator cap and raising the overflow bottle to get a head of pressure.
Question is, how to stop the leaks I've noticed (i.e. there may be others)? A drain, flush and refill is probably a good idea anyway but will just remaking the joints after cleaning and using new clamps stop the leaks (should I use something on the radiator stubs before pushing the hoses on?), Or should I fit new top and bottom hoses? If so, where's the best place to get them? Neither Renault nor a couple of local factors I've tried can help me
Many thanks in anticipation of your suggestions.
Mark B
Mark B
