Thanks for that . The old steering rack did have solid track rod ends but the new one has the screw adjustable kind . So is 5mm toe out the maximum ? I was thinking of trying parallel first to see how it steered and then I could adjust the toe out from there .If you have the solid track rod ends the toe out is 0 to 5mm , as a general rule only rear wheel drive axles have toe in and front wheel drive toe out.
