G Giles Enthusiast Messages 40 Location Sussex Nov 4, 2024 #1 Hi Any hints or tips on how to remove an old windscreen (whole, to use as a pattern), and fit the replacement? The rubbers seem good, but I guess I will find out how good while removing the old windscreen. Thanks
JdeW Enthusiast Messages 1,012 Location Laarbeek The Netherlands Nov 4, 2024 #2 Here's a good tutorial https://www.la4ldesylvie.fr/depose-et-repose-d-un-pare-brise-d-une-custode-ou-d-une-lunette-arriere
G Giles Enthusiast Messages 40 Location Sussex Nov 4, 2024 #3 JdeW said: Here's a good tutorial https://www.la4ldesylvie.fr/depose-et-repose-d-un-pare-brise-d-une-custode-ou-d-une-lunette-arriere Click to expand... Thanks! I knew I had seen one somewhere...
Andy McGhee Enthusiast Messages 1,630 Location Cheltenham Nov 4, 2024 #4 If the windscreen rubber needs replacing, there's a good used one here: Joint de pare brise avant avec emplacement pour un jonc pour renault 4l berline et f4 :: Palace de l'ancienne www.palace-de-lancienne.com Fitting the screen is straightforward if you have someone to hold it in place while you pull the cord from the inside.
