Using a wheeled hydraulic jack....... Use the curved cross member bolted transversely to the chassis at the front situated under the gearbox as your lifting point. Raise vehicle carefully...... now you can easily place your axle stands under the front floor bulkhead corners adjacent to the front jacking fittings. It's best to use wood pads to cushion/spread load...... Many thanks to Mr Reno 139 for this useful tip.
