malcolm
& Clementine the Cat
- Bedford UK
Wondering whether anyone can shed any light on a weird clutch modification found in Ornella the '65 Renault 4?
Fredrick the Frog has been having fun again. Ornella's clutch had been slipping when I bought her. This turned out to be partly due to poor adjustment, but decent adjustment didn't seem to improve things a lot so I thought I'd take the engine out to have a look.
First thing to jump out at me were the remains of the carbon release bearing. A replacement clutch and clutch plate had been fitted and the hole in the release bearing plate was too big for the release bearing. Here's Ornella's clutch plate (left) and an original Renault one salvaged from a '67 car (right):
Ornella's clutch plate also seemed taller than the original part, and the spring tension was much less than the original:
Ornella's release fork had been modified too. I can't imagine what trouble someone has had with this clutch in the past. See the differences in the angle of the ends of the release fork:
The mod has involved a strengthening plate being welded on. I'll trial fit and find out if my original Renault one is bent and Ornella's one has been straightened and reinforced, or whether some other funny business has been going on.
I'd hoped to buy a new clutch, but parts for pre-68 Renault 4s seem thin on the ground and I've not been able to find a replacement. The original Renault clutch is from a 18,000 mile from new car (that had otherwise rusted into the ground), so I'm planning to clean that up and fit it - still seems to be within spec.
has modified the arm to accomodate a replacement clutch cable that was the wrong 'adjustable' length, i.e. He has used whatever he had lying round. It would be useful to compare it with a verified correct cable. My renault supplied gtl replacement was quite different to the original - the bulkhead cable gromit was much smaller although the adjustable length (happily) was identical. I was worried it would be wobbily:eek: but it was ok. Some 'numpty' had poured vast qauntities of heavy engine oil down through the old one which doubled its resistance - it was actually frayed. Sorry to drone on...... shut up Brian......keep it short....:smile:
I noticed the 3 speed transmission mount is quite long - would removing that generate enough space to remove the gearbox without removing the steering rack and radiator? The difference was only a few wires once I'd removed those.
