Hello,
what do you mean with "hat rack" ???
Compare these 2 pictures of the car, when I bought it, and few days ago...
Last week-end I continued to sand the filler primer, as you can see the "pitting" tend to disappear with the help of this primer, at the top of the second photo, it has been sanded and the surface is about perfect:
Then I resigned myself to make a job I hate, because I think I'm absolutly useless idiot in this kind of job: body filler :eek: :eek:
The top of the door has been damaged with the grinder I used to remove the rust, too hot, too fast, the steel has now "waves" as you can see on the rear door on the picture above:
I started to sand the doors, by hand for the little areas, and with a sanding block with the right panels, I used 120 dry paper:
After sanding the primer we can notice that the surface is out of shape: at some places Rustol re-appears, at some others, where there are hollows, the primer is not sanded:
I applyed a first coat of aluminium filler, why "aluminium" filler ??? Simply because it's the only one I had when I made the job, and also I was heard that it was stronger than "classic" filler...
After drying and sanding with 80 and 120 paper, I put a second thin coat of the same filler, It is better already a lot
Tomorrow I hope to finish this stage of this awful job, and apply the final primer before painting
