Douglaski
- Spain
I hope someone can help, and apologies in advance for my extreme ignorance and novice questions.
One of the steering gear boots was burst so I have removed the steering "rack" in order to replace same, and generally check it all out. I am glad I did as the bushes at both ends are in need of replacing. However at the tail end of the removal job - releasing the last two bolts to the sub-frame, with the nut end blind, out dropped these shims(?). Can anyone please advise how these should be properly remounted.
thanks in advance.
thanks in advance.
