laxeian
- Earth
Thankfully it seems to be good news week, checked the valves are seating correctly by refitting plugs and filling combustion chambers with petrol, no leaks on any of the valves, did the same thing with petrol down the cylinder bores, rings fine ( will be changing oil-filters as a matter of course), borrowed a flat/true machined block to place on top of block whilst sliding it across block liners with a bright light behind it, no visible light seepage to be seen as sliding it across, same procedure on head, same result so it looks as if after these checks I was v-lucky and have just had a head gasket failure causing the low compression. Also been recommended a local good machine shop,( see how good they are 1st,v-tempted with the 1.4 conversion I have read on other threads here) so head and manifolds will be getting a light skim before all going back together to be sure to be sure.
Tried contacting that bonnet Andy, tried and tried, guy must of gone on holiday after placing add!
