I thought that it would go something like "double holds it better"![]()
I do hope everything will be aligned. Malcolm used chassis jig for extensive chassis work.
very thorough job you are doing wish i had your time and skill
guess you have done other cars before ?
keep at it, very inspiring
regards Paul
very nice job David, your chassis will be absolutly NEW
Thanks you also for your proposition about your wheels, if I find here 2 others one to have a set of 4, I will certainly ask you to send them to me. Can you tell me the cost of postage ? (Germany to France, I'm a little afraid :eek
I'm looking forward to read you soon.
A
I forgot the most important, actually I start to repair the chassis of my brother new R4, a 1981 GTL, as you, the rear of the chassis is damaged, but luckily less than yours![]()
As Malcolm did on Rosalie, I started to cut with a grinder the damaged section:
My question is what the thickness of the steel sheets you use to repair this part of your chassis ?
Personnaly, I think I will make the repair with a single 2 mm steel sheet instead of 2 ones to prevent the rust between them...
Thanks you for the informations![]()
