4GTL carb
Mr Hennessey and Pepper you are clever boys.
I extended the trunk from the air cleaner to very close to the exhaust .I have been out for a 15 mile run and the only thing constraining my speed was my courage on these winding Lincolnshire roads (not having driven a four before)
I went into my Renault agent and the rubber pipes from carb to water pump are still available so they too are on order and I shall fit the whole kit when it arrives.
Although my carb is an SEIA I am not sure what it was for I notice that as well as earlier 4s it was fitted the lower spec R18s I assume with different jets.
Many thanks Gary
:cool: Glad to be of service. If you want to be really clever then make a box to fit round the front pipe to capture more of that hot air!!
On my 4 I made a temporary unit using a Mini intake so when the air is too hot, the flap opens and lets in cooler air. Saves swapping intake pipes around winter and summer. Mine was a bit Heath Robinson but a permanent unit could be easily made.
