More news. I have found the cause of the high pressure. In the oil pump is a relief valve if the pressure is too high (right Malcolm). It is a plunger with behind a spring. If the pressure is too high, the spring is compressed , the plunger goes backwards and a hole appears that brings the oil back to the entrance of the pump. The plunger was blocked. It was covered with something that looked like dried oil. I have tried to free it with compressed air but no luck. So I drilled a hole in the opposite wall and could free the plunger. In the hole I have put a treat and a bold. Tested it afterwards with compressed air and back in the engine. The pressure was limited to 4 bar. Still high but not unlimited any more. I think I solved the failure of the oil filter gasket.
Now the Nulon. I found some of it in the carter. So it is possible it will disappear in time. I want to have more info about it and will try to contact a representative of Nulon To hear how the process normally goes. If the pump was ok from the start, I would not have noticed the Nulon causing a higher oil pressure. Still thinking about it. All ideas are appreciated.
Regards, Bart
The plunger with a film on it
the relief valve the shiny bold is the place where I drilled a hole to unfasten the plunger
The pressure , now limited;
Regards, Bart
