Thanks for your support!
I released the handbrake to get some room for my hands when i fiddled with the master cylinder. So i'll put it back on before i continue now. I had no idea the hand brake did that. I have auto adjusting brakes though, hopefully they work.
I have bought 2 different diy bleeding kits - one where you connect a non reurn valve out on the wheel end (goes down into a can), and one where you put pressure on the top of the master cylinder containers. Unfortunately the lid on the pressure kit does not fit the R4, so i've drilled a small hole in one of the original lids and use a regular compressor (instead of a wheel). Both methods seems to work. I'll try the non return valve today, and if that does not work i'll phone my brother and do a 2 man bleed again.
Actually, i'm full of hope
I'll let you know how it went!
