Steve Hennessey
Moderator
Matt, there should not anything 'officially' in the tube so someone must have put it there for reasons unknown. The only 'restrictor' that Renault did use on some models was a piece of tube at the vacuum end of the distribuor with a tiny hole in it. This was a mod to prevent the vacuum unit from advancing itself too quickly i.e. to reduce the amount of suck. Please do not change the setting on the small cog in the distributor as this is set at the factory.
If the vacuum unit has not been working at all then this may be the cause of your problems. I thought you had checked this out previously.
