dreaming mechanic
- France
hi
my r4 started chugging i wonder if it could be the tank
THANKS
THANKS
HI
thanks for all that advise . Today we drove it and it was pulling how do you adjust the points on a renault 4 4l 1978 billincourt because i can t find any videos on how to do it if you could show me the n would be helpful and i going to put a video of what the engine sounds like
There is nothing that can leak oil above the tank...there oil all over the oil tank and its losing oil
If the sump is covered with oil, wipe it clean and then see if you can spot where the oil is coming from. If you're lucky, it could be something simple like a leak from the sump plug. If your car has an oil filter, check to see if the oil is leaking from its seal with the engine. If the filter has been changed recently, it might not have been fitted/tightened correctly - they're more difficult to get to on Billancourt engines.there oil all over the oil tank and its losing oil
I'm sorry, I read tank and I supposed it was the fuel one.If the sump is covered with oil, wipe it clean and then see if you can spot where the oil is coming from. If you're lucky, it could be something simple like a leak from the sump plug. If your car has an oil filter, check to see if the oil is leaking from its seal with the engine. If the filter has been changed recently, it might not have been fitted/tightened correctly - they're more difficult to get to on Billancourt engines. View attachment 28110View attachment 28111
If you've taken the rocker cover off the top of the engine recently, have a look for leaks there.
Some photos would be really helpful.
Good luck!
