nudger2802
Hi guys and gals, I am a newbie and just wanna say hello to everyone out there first before I come grovelling for help lol.
Anyhow I have recently purchased a 1994 Renault 21 savanna 1.9D for a cheap runabout that I can pile the family in and we all love it to bits but yesterday morning it decidied to die
Ok its done more miles than the starship enterprise but it was running as sweet as a nut before.
I started it from cold and just revved it a little to around 1500 rpm to try and get it a bit warm before we set off and after about 20 seconds it died. I tried re starting it but it seemed very lifeless just spiining over freely and not even trying.
I spent several hours yesterday, taking out the fuel filter to see if its blocked but it seemed brand new, bleeding air out the now disturbed fuel filter bleeding air out the fuel inlet pipe on the injection pump, all fine with plenty of clean fuel although the primer pump on the filter head does feel a little weak.
Still nothing so I tried cracking off the injector pipes to see if they needed bleeding and nothing whatsoever is coming out of them no air no fuel nothing when cranking over.
I am no diesel expert but surely fuel should be being injected when cranking so that the engine will start?
I have tried connecting the stop solenoid direct to 12v and can hear it working fine and have also tried to turn it over with the plunger removed from the stop solenoid just incase but still nothing.
The engine will fire when brke cleaner is sprayed down the air intake and will rev its head off happily like this but no fuel is getting through so it just dies again.
Am I being a plonka and missing the obvious here and have overlooked something stupid or do you guys come up with the same theory as me and think the injection pump is past its sell by date?
Sorry to have waffled on but just wanted to get all the info in from the start.
Nige
Nige
