djoptix! sorry to revive this old tread..am in the process of drawing cables for cd/radio and looking at the connectors -All by ISO-standard (I'm talking about power-connectors)
-they are:
Yellow +12V Permanent
Red +12V Switched
Blue +12V Auto-ON for extra amp/antenna/DBX etc
Orange +12V Illumination
Black Ground
being a sound-egineer I guess you know what youre doing but seing the ISO-standard disagrees with you re Yellow and Red (+12V constant and after ignition) some could get confused and throw the radio out the window ,so it would be nice to have it correct right?
The new ISO-standard also incorporates a BROWN cable which is to mute your Bluetooth-phone (not all ISO-connectors have it so if you can't mute your phone here's the reason.....
Finished cabling to speakers. Heck of a job to open the ISO-connectors and pulling out the contacts to change the joke-cables they installed for some more hefty ones-and why the H*** do they cross signal and power-cables when it's not necessary??? silly buggers!
PS: I see elsewhere that lots of you guys install Cd-players in the "original"R4-radio-console and having no problems with that-which is all Good. -Beware though all cd-players are meant Not to be mounted at an angle more than max 30 degrees,you might get it to work but performance will not be as good as if mounted correctly.The cd spins at high speed (variable) and both platter and lazer plus correction-system
is working overtime at all time if mounted in exess of said 30degrees-just so you know why its skipping and having black-outs and Lo-fi perfomances -R.
