- Bedford UK
Worth an ask to see if anyone else has any ideas. The Gordini has the Renault 5 Alpine engine with a Weber carb.
Been fiddling over the last few weeks. The ignition timing was much improved by fiddling with the advance curve http://www.renault4.co.uk/tech-pinking.htm
Fitted a new throttle cable at the weekend and made sure I could get full throttle - might not have been getting it previously.
Since all that I've found if I floor the throttle suddenly the engine dies for a second before doing it's thing.
I've checked the throttle pump and it's working perfectly. Ignition timing is set as advanced as it can sensibly be without pinking. Vacuum advance works (and has some adjustment to alter it's limits that I haven't fiddled with). Points were new about 2000 miles ago and haven't been cleaned but seemed good after 500 miles.
Only thing I've found is the dwell angle had drifted to 50 degrees so I altered it to about 58 degrees tonight.
Might be a blockage in one of the jets - idle jet seemed to become blocked this afternoon so I've hosed them all out with an air line tonight. Got a filter on there and everything seemed clean, but definitely one blocked jet this evening.
I shall report back on how it goes tomorrow, but really asking in case this seems an obvious symptom of some malaise that might make it awkward to do 1500 miles over the next 2 weeks.
