AdamWilkes
- Poole
Richnd1974: It's worth unbolting the flywheel and replacing the crankshaft seal (that's usually the source of the leak you are seeing anyway), and the camshaft seal.
Recommend light smearing of gasket sealant/silicone around the outside of the new seals Just In Case - I've scratched the metal seal-housing when removing the old seal in the past, which WILL weep oil later if not sealed. Hard to see the scratch, hard to repair later!
