Crunching numbers and crunching on.
Torqued all the bolts that needed to be torqued.
Looked up the motor numbers and found out that it is indeed a R18 engine
The motor number is 847/ 20.
And the leaflet that came with the head gasket says that is for a R18
So I have to change the header on this topic.
But according to the leaflet the R12 had a 1397cc engine as well.
I put in the oil pump and put on the sump and some auxiliary parts.
Finally it looks like an engine again.
I also found the formula to calculate the compression ratio.
So I crunched some numbers.
The formula is:
Stroke volume + combustion chamber volume / combustion chamber volume.
The stroke volume is the easy part.
1397/ 4 = 349ml
The combustion chamber volume is a bit more difficult.
So I took another 1108cc head that was laying around. Put it on a horizontal place with the chambers to the top. And filled one of them with water. This head still had the head gasket attached to it. With the same thickness as the new gasket on my engine.
It took 42ml from a syringe until it overflowed.
So I estimate the chamber volume on my engine as 45ml.
In the calculation it gives.
349 + 45 / 45 = 8,8:1
Well within save margin for a petrol engine I think.
And this is the result for today.
