Geoff in the Gully
Getting it together
Here's what I was thinking of for the 'modest improvements'.
Most are based on my experience of living with a 6-volt Dauphine and its compromises
1. 4-speed gearbox instead of 3-speed - for a little bit livelier performance
2. 12-volt electrics - 'cos 6-volts is so finicky on the connections, alternator instead of gennie
3. Disk brakes - drum brakes all round are just hard work and I like my cars to stop, sometimes like RIGHT NOW
4. Electric radiator fan - in Australia cooling can be problematic
5. Sliding windows in rear doors - fixed glass just seems too closed in for the rear passengers
6. Split system brake lines - improved safety
7. Heated rear window in hatch - better visibility on wet nights
8. Reversing lights - improved safety
All these are are things that later model Quatrelles had so I figured I had a good chance of finding part to suit. I'm not so sure of the last two though; I'm probably not going to use him much in adverse conditions like wet dark nights. The other ideas would be largely 'invisible' to the untrained eye - of course any R4 aficionado would see that they're not original to the year and model.
Also
9. 2-speed wipers - but maybe not, as above
10. Relays for headlights, horns, fans - stop burning out wires in main looms, for brighter lights
11. Dauphine Gordini carby and dizzy - some improved performance
12. Brake booster - for stopping better. Ok, so I have a thing about having really good brakes - I got my reasons.
13. Maybe a temperature gauge
I'd found Clementine's Garage by then and had started reading all the tech info. Gosh but I'm glad you guys have done all this wonderful work. Anyway, it led me to believe that most of the above would not be unduly difficult to tackle. After all the whole car is being stripped down totally and rebuilt from scratch. As long as I decided what I wanted to do up front I could 'mix and match' to an extent.
I did think about trying for a bigger Sierra series engine - it would be like the R10 - but I noted Malcolm's opinion that the extra weight altered the balance of the front to be less sweet. I decided that I stick with the 845cc and liven it up a bit.
The final idea I had at that time was to seriously improve lumbar support when the beach-chair front seats were redone. The missus has a bit of a dicky back, so do I to a lesser extent, and I thought that if I made it really really comfortable for her we'd be allowed to go out an play with him more
Of course, there's a bit of working out to do with these ideas.
Also
