mojobaby
You managed to get it started last Friday with the help of a friend.
If you're 100% sure that your timing is correct, then check the condition of the distributor cap. Clean up the terminals and make sure that the centre carbon brush isn't stuck in. It's got a spring so when you push it in, it will pop out again.
Take the leads off the spark plugs one by one and hold the tip about 5mm from the engine block while you turn the engine over. you should see a spark.
Clean up your spark plugs with a little wire brush and some fine sand paper.
If you have a spark at the plugs and it still doesn't start, then your timing is still out or you have a fuel supply problem at the spark plug area.
I would imagine that the tip of your plugs should be a bit wet after turning the engine over a few times
