'Special' tools
Andy McGhee
Cheltenham
I thought I'd start a thread about favourite tools - those that are commercially available, and those that forum members have made or adapted.
Here's one as a starter - a tool for removing the fuel pump on older TLs (Billancourt engine) - made from an old bicycle spanner.
Made the necessary tools Billancourt engine rebuild. More tools and explanation in thread above
List of everyday "weapons", left to right:
Rear suspension arm positioning tool
Rear gas damper compressing tool
Set of lower wishbone bush extracting tools
Front drum brake hub extractor
Billancourt distributor bush extractor
Billancourt cylinder head bolt socket
Tool for unscrewing differential bearing carriers
Plug for differential output seals when driveshaft removed (top) / post-79 steering rack boot installer (bottom)
Bottom:
Speedometer worm gear spanner (other end is for the 385 R5 Alpine gearbox)
Brake adjusting tool - commercially available
Front torsion bar anchor lever spanner
And, on its own, the engine removal/installation hanger.
Bottom:
Very impressive @angel
B.t.w. I'm in Athens from 3 'till 10 july 2025 to admire Greeks capital and monuments.
