malcolm
& Clementine the Cat
- Bedford UK
Normally overheating problems will push water out of the expansion tank. If the fan comes on sometimes and you never have to top up the water in the expansion tank I would guess your car is operating correctly.
(If the radiator fan doesn't come on before the car boils it is normally because the cooling system isn't pressurised or the fan switch is faulty, dirty connections etc.) If the fan comes on after a long period at idle and switches off again for a while then the system should be OK.
It does sound like the temperature sensor on your car is faulty. The light can also come on if the wire to the sensor touches the exhaust manifold and melts.
