angel
- Athens, Greece
This info is missing from all manuals, official or not.
Many years ago, when I first encountered this problem, I had thought a method of marking an inner mounting fixing hole position in relationship to (previously installed as per the manual) outer bush mounting. It worked but was too fussy in the end, so next time I made it easier. I turned a dummy inner bush from plastic and used this to temporary locate the inner mounting on the arm. Having installed the outer mounting as per the manual, I offered up the suspension arm on the chassis and marked the inner mounting position in relationship to the arm. Then I was able to press the inner mounting in the arm in the correct angle by aligning the marks.
This "special tool" is not entirely necessary, you can simply bolt the inner mounting on the chassis and fit the suspension arm / outer mounting, then mark the arm/inner mounting position while keeping these parts roughly centralized.
